Foz
All,
Am seeking some trouble shooting advice. I have a 30w solar panel with an open circuit voltage of ~18v, in line with manufacturers spec. When I connect it to the controller, the voltage drops to 12.45v. I have checked the voltage at the built in solar panel cable to boat cable junction and again both are 12.45v either side of the joint. The solar panel volts at the controller are also 12.43 - so not too much loss. I have a dual battery set up with the engine battery volts at 12.83, the domestic battery is at 12.3. The controller led indicators all appear normal for battery charging. My battery monitor is only showing 0.1A of charge much of the time, best I have seen is 0.3A, I was expecting ~1A? After a week battery volts remain unchanged consistent with 0.1A?
Is there a problem with the controller, have the batteries gone past their useful life or am I missing something?
Thanks in anticipation....
