stu9000
I took off a small 4w solar panel that had been fitted by the previous owner. rust was destroying the connections so a bit of TLC was required to get it through one more season.
Not really boat kit but last season it seemed to do a good job of trickle charging the batteries. Putting it back onto the boat there is no clear positive or negative on the wires that lead to the batteries. It isn't easy to trace them back visually either.
Does it matter which way round I connect the panel?
Would a tester help? I do have one but, as you can tell, I lack some expertise in this area.
