charles_reed
Cruising in the Med, I've found a fridge essential, life has been miserable during the occasions the power rectifier has packed in.
The critical factor is how efficient the fridge might be. That's a combination of a number of factors:-
efficiency of the cooling unit - if an expensive Danfoss unit a draw of 5 amps on start and 4 when running for 10% of the time, if a cheap Peltier unit the same draw for 100% of the time
effectiveness of insulation - I'd not reckon much on the exiguous insulation on a caravan unit or one which loses all its cold air when you open the door
How often you open the unit and whether you put warm food into it.
As the OP has not even hinted at the fridge type/use most of the comments posted are wild guesses.
