A1Sailor
I am considering purchasing a small solar panel to trickle charge while my Sadler 25 is unattended on a mooring. Boat has two 12volt batteries; one for engine start, one for domestics, with independent on-off isolator switches. Another switch to link the batteries if required.
There is a Volvo-Penta sensing charging distributer between the alternator and the two batteries. I think this charges them separately according to their state of charge. I wouldn't want to do any harm...
There is an electrical socket in the cockpit to plug in an autohelm for the tiller.
The plan:
- small solar panel, without regulator, which can be plugged in to the cockpit socket
- domestic battery left turned on, with "autohelm" power switch left turned on at control panel.
Questions:
- will the above work?
- What is the recommended maximum rating for unregulated solar charging? It is related to battery capacity, I think.
- will a 20W solar panel to trickle charge at ~1.5amps be OK unregulated? Not sure how big the battery is, only bought the boat last weekend, but it won't be more than 100aH.
I could, I suppose, purchase a bigger panel and a regulator - but not keen to run new cabling/drill holes on my new boat just yet! All I want to do is to be able to reliably start the engine, using a full domestic battery should the engine start one be low.
Would appreciate others' experience. Thanks, A1
The plan:
Questions:
