BabaYaga
The terminal I referred to is the one to which the charge warning light is connected.
As I understand it, when I turn the "ignition" on, +12v is supplied to the charge warning light and earthed through this terminal, providing a small current through the field coil. As the resistance of the coil is a lot less than that of the bulb, everything downstream of the light is at near enough 0v, so the relay stays asleep. When the engine starts and the alternator spins up, this small current provides a magnetic field to start the alternator generating current, at which point it's fed by the output from the alternator. The terminal is then at +12v, so the spilt charge relay wakes up and the warning light has +12v on both sides, so it goes out.
Sounds like a good explanation. Thank you.
