ss2016
I have a 150Amp alternator which charges a 300AH house bank and a 100AH starter sealed lead acid batteries through an Argodiode. The Argodiode senses the o/p voltage on the output to the starter battery and compensates the voltage loss across the diode.
I added a 100W solar panel to keep the batteries topped up through a Victron MPPT when in the marina which charges the house bank. Also, a DC-DC Victron from house to the starter battery. (Coming from sail I have a major concern about the engine not starting!)
I have noticed that on a 2hr run the alternator does not get the house batteries back to a full state of charge. I am wondering if I used the solar to charge the starter and dc-dc to the house bank if this would cause the alternator to work a little harder resulting in a better state of charge in the house bank.. The logic for this, and I am far from sure its correct, is that with the dc-dc feeding from the starter battery to the house bank while the engine is running , would slightly lower the starter voltage, thus causing the alternator to work a little harder. This would result in a higher o/p voltage not only on the starter bank but also the house bank.
Thoughts? Experience? Thanks.
