mainsail1
I was surprised at the way he dismissed any anchor with a hoop without proper explanation as to why.
I'm a bit puzzled by this note - Optional roll bar for sailboat application. Why would a sailboat need a roll bar whereas the statement suggests power boats don't? The type of boat has no effect on an anchor's performance.
The Ultra anchor is certainly a very good anchor, but amongst the many good results I have observed, there have been a couple of disappointing performances. Anyway, take a look at the many photos I have taken of the Ultra underwater and make up your own mind.
This is one of the occasions when I was disappointed with the performance I was observing. It was only at 3:1 (after allowing for the bow roller height as you should do) in only 4m water. This is a tough test.
The Ultra set nicely and rotated level in a reasonable distance, but a lot of the underside of the fluke is still exposed. The set is much more a piling up of the sand rather than a diving down of the fluke. Worryingly, it was still gradually moving backwards in the gusts rather than digging in further. You can see the puffs of sand that are given off as it shifts back. Notice how the chain is lifting during the gusts, as you would expect for this wind force and scope, but the chain angle is still reasonable:
I had a Rocna, now I have a spade. I hated the roll bar for what could get stuck in it or it could hook on to. However now I worry that the Spade is not as good as the Rocna... The truth is I haven't had a problem with the Spade, but when you have had a Rocna it is difficult to have that much confidence in other anchors.
I am however convinced that the Ultra is better than the Rocna but the sheer cost is holding me back.
One disadvantage with the lead tipped weighted anchors is that it seems for me anyway that the recommended weight of anchor is more than the previous gen of anchors. For my little 26' 2250KG boat Rocna themselves emailed me to say I need a 10KG anchor with a minimum of 7mm chain (even though it says 6mm on their chart) The Spade comes out even heavier at 10KG plus but the Kobra is 6-8KG on their chart as is the Delta!
I think a large factor is that by recommending small sizes the anchor model is more likely to be chosen by high volume boatbuilders (such as Beneteau etc) to be sold as standard equipment. It enables the boatbuilder to choose as small an anchor as possible without violating the anchor manufacturer’s recommendations. This has savings for the boatbuilder not just for the anchor itself, but more importantly for the anchor winch, bow roller and other associated equipment. These have to be sized to cope with the anchor weight. Lewmar recommends very small sizes for their Delta model and I think it no coincidence that this is the most popular anchor included with new boat purchases. To compete in this market other manufacturers are forced to follow suit.
This is not correct, or not in Lemar's or Vetus' case.
Yacht manufacturers try to buy as much product from one supplier as possible - this means they can place on order with the component supplier and arrange one delivery. They can demand of the component supplier that pallets are made up for individual yachts, so they can have a series of pallets for a 35' another series of pallets for a 40' etc. This is especially valuable where the manufacturer of the yacht is building in countries other than their main location, say building in Poland or China etc
Few manufacturers can supply everything but Vetus, Plastimo and Lewmar do a pretty good job.
The choice of Delta is thus because the yacht manufacturer is focussing on Lewmar for their hatche, windlass and anchor etc. The Vetus range is not quite so extensive and they tend to play second fiddle. By buying in bulk the yacht manufacturer can also demand keen prices - which the boat buyer, hopefully, enjoys. The boat builder thus sources all the bits and pieces more cheaply than we can and probably more cheaply that a custom boat builder can negotiate.
The end result is that that many yachts are commissioned with a Delta anchor, though I have seen them, some French yachts, with Plastimo's Kobra . I have also seen French production yachts commissioned with Spade (there is a lot of loyalty to country).
If the boat builder wants to have a bigger anchor than Lewmar recommend, Lewmar will comply, and if the new owner of the yacht wants a bigger or different anchor, the boat builder will comply - but the new owner pays extra, extra as its a special (so guess what usually happens)
The anchor size supplied by Lewmar will meet Classification Society requirements as many yachts go to charter.
The size of the anchor will have no impact on the size of the windlass - the weight is in the chain not in the anchor - so the suggestion that choosing a smaller anchor allows a smaller windlass is, basically, absolute rubbish. The idea that upsize from a 10kg anchor to a 15kg anchor will demand a bigger windlass is a good joke - and brought a smile to my face (in these times anything that can make you smile is good! ). Oddly, and I confess this is subjective, but the feeling I have of new yachts is that they are supplied with chain larger than necessary (anyone who has made an accurate assessment - it would be useful to have feedback). My larger chain assessment maybe one of these choices made by the customer.
As I have mentioned previously
If you average the spread sheets for Bruce, CQR and Delta and plot them against vessel size you will find good overlap, there are some discrepancies because the anchor sizes sometimes do not over lap. If you now do the same for Supreme, Excel and Spade and plot their averages and compare the 2 plots - they are almost identical. So though the new models have twice the hold of the old models the manufacturers choose not to recommending down sizing - they choose to double the safety margin. As someone pointed out it does not show much confidence by the newer models in performance.
This latter contradicts Classification Society recommendations where a SHHP anchor can be 30% smaller than a HHP anchor, so instead of the 15kg Delta you could use a 10kg Supreme.
Bucking the trend, and I have not made an accurate comparison of their complete range, but Viking seem to be recommending smaller (sorry let me be accurate, lighter) anchors (vs the size of yacht) and the owner of Viking, I believe, is using a Viking 10 on a newish 43' Jenny. Their Viking 10 is about the same size as many other 15kg anchors - because they use HT steel in the fluke (saving weight - and its surface area not weight + design that produces the hold). Their quoted holding capacity data reinforces what they recommend and my test of a Viking 10 largely re-confirms their data. However it is not only surface area but fluke thickness - a thinner plate, again the use of that HT steel, of the same design will produce more hold. If you don't believe this - go find a thick plate of steel and a thin plate - tell me which is easier to force into wet sand.....
You can as Noelex suggests opt for a bigger anchor - but as the 2 threads seem to underline, 'Dragging of Anchors' and 'Dragging of Anchors 2' (you need to use the YBW search engine to find them) most people seem to think this unnecessary as having bought the recommended sized new gen anchor - they have not dragged. Interestingly it is not that they have dragged less frequently - they have not dragged at all. So buying a bigger New Gen anchor is, well - a waste of money (and if I'm wrong and Noelex right - you need a bigger windlass! ). But if you have plenty of money - why worry (except there are downsides with the bigger anchor - it will not set so deeply, might leave some of the anchor protruding and in a change of tide the chain might trip the anchor.......
Jonathan
Very true, always very well put together. What else would you expect from a former professional cameraman and mainstream tv journalist?What a very high quality video. Approaching pro production standards. Lovely to watch.
Great to see some loads for given wind strengths.
Would be very interesting to see a similar test with no wind but 1m waves or more.
I think you’d pressed the quote button. Do you want your text back?Deleted due to YBWs forum software doing weird things
