dom
This step sounds important. What does it add to the spring/snubber though?
It’s very important, a relaxed owner makes for a relaxed and supple snubber
Not really: rope construction, material, age, etc play a big role in elasticity characteristics.think the general opinion is that is must not be too thick or else it defeats its purpose.
Precisely.
If you have poor anchoring gear
Newish rope is a lot more elastic at low % of breaking strain than at high % (elongation curve is S-shaped) so the bigger you use the more % elasticity you have; then new rope eventually becomes old, a different thing, plus there is 3_strand vs octoplait, polyamide vs polyester, etc etc all contributing factors. Take a few different types and see what happens in real world use, no need of a hurricane, elasticity difference is often 1.5-2x so rather visible.![]()
Rupert,What I have and what I would choose if starting from scratch are two different things.
42 foot boat that wanders 60 degrees either side of the anchor sometimes with max force when it changes direction. We have anchored most nights when cruising over the last 10 years but less so in our curent cruising ground. Often in 40 plus gusts and once saw a 60 plus but only a couple of times had waves (rather than swell) coming into the anchorage.
What we have is 60m of 10mm galvanised chain shackled to 60m of 12mm nylon 3-strand (although I haven’t used the warp since adding it 4 years ago). Our snubber is also 12mm nylon 8m long with a thick rubber dogbone that increases in length about 70cm . It is attached to a chain hook (which I always prefer to something captive) with about 2-3 metres from bow cleat but if very windy forecast I’d let out the full 8m.
Your fixed length bridle does have a potential flaw. We normally choose to anchor in around 5 metres. An 8 metre snubber might well allow the hook to touch the seabed, which is the only circumstance in which a chain hook can release itself.We have 80m of 10mm chain and only 1 bow roller. I use a bridle (so the snubber doesn't have to share the same roller) of 14mm anchor plait and a 3/8 ... 10mm chain hook.
Each leg of the bridle has a loop spliced into it and I simple put those over the forward mooring cleats and then through a fairleads. The anchor plait is protected by "layflat hose" as it goes through the fairleads.
The bridle is about 8m long (each leg) and at the chain hook end the anchor plait is secured around a SS thimble, and held by stitching through the anchorplait and then whipped.
The boat is 14m and fully loaded is about 16 tons. We've anchored like this in remote sheltered Scottish West Coast Lochs with the wind gusting at over 40 knots and the boat shearing around, partly due to the wind gusting off the land, and partly due to the very narrow lifting keel, which doesn't have much lateral resistance.
This arrangement has lasted well for around 6 years with about 100 days at anchor per year.
You can really see the nylon anchor plait stretch when I set the anchor, by going slow astern.
Nylon will stretch to around plus 60% of it original length before it breaks, which makes it ideal for use as a snubber.
Rupert,
What you describe sounds like classic (and sometimes destructive) veering. Have you thought of rigging a bridle, there are ideas in some of the posts - but from the amidship cleats and through the bow fairleads (with suitable abrasion covers).
The bridle might help to tame the veering and keeping the bridle short beyond the fairleads will maximise the separation of each arm - if its a long narrowg 'V' it will act more 'like' a single snubber.
Jonathan
The bow is about 2m above the waterline, and the mooring cleats about 1m back from the fairleads and we often anchor in 5m at low water (draft 3.3m keel down), so technically you are correct, the chain hook could be become detached. However, in the 7 years or so I've been using this system it hasn't happened. I wanted to keep the snubber as long as possible to help absorb the "shock" loading when the direction of shear changes. Like RupertW, the Southerly can swing quire wildly at times and it really loads the anchor up when the 16 ton boat changes direction. Having said that we haven't dragged to anchor, except once when it slowly ploughed a furrow in very soft mud.Your fixed length bridle does have a potential flaw. We normally choose to anchor in around 5 metres. An 8 metre snubber might well allow the hook to touch the seabed, which is the only circumstance in which a chain hook can release itself.
Veering! The best way that I have found to cut down 'sometimes destructive veering' is by using the Hammerlock Moor. My main anchor is a 30kg Spade so for the Hammelock I use the back up stowed away 25kg Spade. So if you are in 8m of water (add 1 m water to bow roller and 1 extra meter) your Hammerlock anchor is now on a 10m rode. Your main anchor is on whatever you have set it at...mayber 8-1 if you can. The deployment of Hammerlock anchor is done at the zenith of a veer. Just put it over and it will now drag along the bottom cutting your veer, in many cases quite dramatically. It also has the advantage of being a back-up anchor if you can work out a system to extend the rode. I have heard stories of boats dragging down on peoples anchor in places like Greece and so having a second anchor ready close to the boat sounds like it may be an advantage.
Chain Stoppers and Snubbers are like beer and crisps.
All this talk of snubbers has been very informative. But there are times when a snubber fails or is incorrectly set or it is pointless setting one up because there is no wind or tide. And setting your anchor with a snubber attached is an art I have yet to master! So imho a chain stopper and a snubber are both equally important.
My chain snubber (picture enclosed) is a chunky 8mm 5/16 Lewmar model. Great piece of kit. But would I recommend it? Well that is another story. But everything is good now and it is the ultimate back up windlass protector with 4 x 7 inch screws holding it down. It is always on when setting the anchor and used when weighing anchor when I have to go below to knock down a cone of chain in the anchor locker.
Some of the best chain stoppers are simple home made ones. I have a back up chain stopper to protect the chain stopper just in case. It is a loop of dynema with an old kong chain hook (the rubbish ones with the pins - the pin is now drilled out) attached. It is simply looped over the Sampson post forward of the windlass and manually attached to the chain making sure there is some correct slack. And actually this would have saved me a lot of trouble instead of fitting the Lewmar! But it is not as quick and simple and ultimately not as safe (for the fingers).
I met one chap who had welded an upside down T shape chain stopper to his bow cleats using very chunky chain and welded his hook onto a link. He was very pleased with his set up, he called it 'bomb proof.' He never used a snubber. Watching his boat at anchor it always amazed me how his chain always hung straight down when everyone else was lifting up and being 'snubbed.'
What is the flaw with the hoop on the Rocna? It's only 2 years ago that I purchased a 16Kg one and so far no problem.I have had 2 Rocnas, a 20Kg and a 25Kg and have found them both to be flawed (the hoop is the flaw). The 25kg Rocna was a great setter at almost any scope! The Spade seems to like to set with about 4-1 scope.
Jonathan
