Keithleask
Hi all, had the boat out of the water for the past 8 months or so while upgrading a lot of things. Before I took it out I had very light engine smoking which an engineer who serviced my out drives ( when it was on the hard) said it could be the injectors need servicing / replacing. Since putting the boat back in only 6/7 weeks ago and not having taken it out anywhere the engines are smoking really heavily. I am thinking I have got a lot of water in the fuel tank. I had an issue with losing power just before it came out which I thought then might be either water contamination or sludge etc on the filters on the fuel pick ups. Why I am leaning to the water is both engines are smoking badly and starting is not as good as it was and if it was injectors surely they would not be all playing up at exactly the same time ? I have changed all the fuel filters, checked the turbos, free spinning, no damaged blades, changed both exhaust elbows and rubber connectors, elbows were corroded , I have probably made things worse because the fuel level in the tanks has been quite low right through the summer and Autumn, around 1/4 or so full. Engines are recorded as 660 hours ,I am thinking of having what fuel is left polished and having the tank cleaned before I tackle the injectors, any advice would be greatly appreciated, thanks ,
PS when I changed the filters in March no signs of water but not checked them since !
