DavidJ
I’m at a loss why the technician didn’t replace the main seal anyway while he had it on the bench. You have already incurred most of the cost of this operation so the cost effect of a seal change would be marginal.
I really do hope you are lucky with an intermittent seal issue that sorts itself out, more likely next time you lift it out, the oil will be milky again.Just an update on this old post…..
The leg was removed and pressure vacuum tested with no fault found (by a trusted marine engineer).
It was refilled with oil and reinstalled.
I’m going to change the oil in a few days so wish me luck!!
Ps. I did loose a prop hub last year so I’m hoping that there was an intermittent seal issue that caused the (potential) water ingress that sorted itself out.
Just had our seals replaced, this was done with the leg in placeLooks like (as predicted) that the seals do need replaced.
Q: How simple is that job? One that a competent DIY’er could do? Can it be done in-situ or do I need to remove the drive and do on the bench?
I’ve done the vast majority of engine services myself and a (car) engine rebuild in the past. But I’ve not done a VP gear casing strip / rebuild before.
I’d welcome the collective guidance!
