skin fittings
bige
6 Mar 2002
i am fitting new skin fittings to my saddler and can any one tell me what sort of sealant to use to bond to hull
thanks big e
snowleopard
Oxford
polyurethane sealants are very effective, eg. sikaflex. avoid silicone sealants as they contain acetic acid which may damage the metal. in any case, leave the fittings loose so as to get a thick (1-2mm) layer of mastic then fully tighten once the mastic has set, thereby getting a good gasket rather than squeezing it all out while wet.
VMALLOWS
9 Oct 2001
Emsworth, Chichester Harbour, UK
I always use a polysulphide sealant for underwater fittings. (LifeCaulk is the most readily available brand in chandlers, but you can get all sealants much cheaper from industrial suppliers). Some people use polyurethane (eg sika-flex) or even silicone. The former will give you a terrible job when you next want to change the fitting, and the latter I simply would not trust under water, especially if application conditions/curing are not ideal.
Polysulphide will also cure happily under water, so there is no problem replacing skin fittings between tides if necessary (assuming the rest of the job goes OK!!).
Plum
6 Jun 2001
UK East Coast
agree with this advice, but recommend you do not get any of the mastic on the underside of the nut or on the threads as this will make future reoval very very difficult.
Gordon
21 Jun 2001
Ian
Are you going to replace the cockpit drain plastic skin fittings?
If so, what with.......I wondered about replacing mine with bronze
version
Gordon
