gjgm
Quite a few insurance policies I have looked at have specific exclusions about boating solo,so I suggest you check. Not necessarily a problem, unless you did not tell them and disaster happens
No reason why not as long as you take sensible precautions. Obvious ones are check the weather forecast and only go in settled conditions, wear a life jacket, have a shore contact who knows you passage plan and timings, avoid any 'over the side operations... i.e. probably avoid the anchoring and going ashore in the tender. These are some of the factors advised by the MCA for single handed ops on coded boats to mitigate risk.....common sense really.
Lots of sailors go to sea single handed so no reason not to in a mobo. The bottom line is your level of competence/confidence and only you can answer that but it sounds as though it is well within your capabilities![]()
Totally agree with Greg,
this year for the first time I have ventured out a few times on my own and once you relax into it you will love it, I only do it mid week as it's quieter and far easier, on a busy hot Sunday it would be a different beast perhaps
Well... just to conclude this .....
I did it!! No problems.... quite enjoyable..... its all about the prep.
I took a sea sick pill..... and fell asleep for a moment at the wheel...... made a coffee.... felt lots better....
In the end I did anchor up for a few hours kip...... the sea was quite calm and safe..... always clipped on though!!!!
