richardtoll
The push rod on my TP 22 tiller pilot has snapped about 20mm behind the plastic tip. I am not getting anywhere with Simrad's support service. Has anyone experienced a similar failure and found a solution? Apparently Simrad do not offer replacement rods. Could I use the rod from my old TP10?
I have had the broken parts welded together but the weld stands pround and will damage the plastic housing when the rod retracts fully. Is it possible to adjust the travel of the rod to avoid this happening?
