DMac
Hi,
I've got a Silva S15 VHF and am having some problems receiving calls on it. First assumption was the antenna connection on the back as we had to do this ourselves when we took delivery of the boat. Last week we took off the connector and redid it but if anything the problem is worse. Symptoms include not receiving any of the transmission or in some cases missing the first few seconds and then it picks it up. The Squelch setting seems to be OK, tried turning it right down and problem still shows up. It appears transmission from the radio is working OK.
At this point considering taking the connector off again and redoing it but not sure what to do differently!!! In terms of putting the connector on the cable we folded the shielding back over the outer cover, screwed that into the connector and then soldered the inner core. Any advice or tips on the best way to make this connection would be appreciated.
Coincidentally we've now been told by the Irish Regulator (ComReg) that they have been notified that the S15 is not compliant with EU regulations/standards - some tests being done in Norway apparently. Because of these they are refusing to issue the license at the moment.... Anybody know any more about this ? I guess if its true then this will not just be a problem in Ireland. Going to talk to them again tomorrow to see what exactly the problem is.
Regards,
Declan.
Regards,
Declan.
