Sikaflex seals
Major Catastrophe
31 May 2005
I have spent most today, washing and polishing the old girl and noticed that some of the sealing stuff has degraded.
The boat is only two and half years old, so I am not sure if this is usual.
Should I just scrape out the old stuff and squeeze in some fesh Sikaflex?
Is there anything I should be aware of?
For a start that doesent look much like Sikaflex, ( second pic) and whatever it is it was badly applied in the biggining.
Sikaflex is one of the better sealants but is best applied to joints when they are been assembled, ie, not applied after like silicone.
G'day Chris,
I doubt that's Sikaflex. You need to remove the old, then prime it and apply the
sealant of your choice, looking at it I think I would be looking for a fast curing
Bostic Polyurethane Caulking compound.
Sticks like the proverbial, easy to work with, lasts for years and still flexible, and
less than Sikaflex off the shelf.
Avagoodweekend......
No it should be primed, the primer will clean the surface and leave a film that will improve the bonding. Talk to the seller, they should have all the info and at least 2 types of primer available, one for mild steel, and others.
Hope this helps.
Did you mean, 'Don't clean with acetone.'?
How do I abrade a 2mm gap and coat opposing surfaces with epoxy?
I didn't realise that refilling seams between fibreglass components was so complicated.
