billskip
I think in an earlier post the OP says he has the drawings.Have you tried asking Oysta how they put it together?
This is an excellent idea, @penfold , thank you. I will consider this next.Do you have access to basic workshop materials like threaded rod, nuts and steel angle? You could make an extractor set like this, screw or bolt the flanges to the skeg and casting and wind them apart; along with heating it should get it off. The threaded rod could be welded to the upper flanges or just fixed with nuts.
Originally, Oyster. And then us when we refitted 12 years ago. Funnily enough, I've been speaking to another Oyster 435 owner who did his own refit and had exactly the same problem. He said it was an absolute **** of a job, as we're finding out. When we eventually put it all together, we will NOT be using epoxy!Having watched the video it all becomes clear. Whose bright idea was it to epoxy the thing in place? I think I've had to drop my rudder three times in the last 20 odd years (shaft removal).
It think the bottlejack / sledge hammer shock treatment / high heat is the way to go.
Good luck. Don't do it again.
This will have to be removed when we eventually remove the bronze from the rudder, but taking it off now doesn't help. There's a gap between it and the bronze, no pintle.Edit to add. Might be worth “attacking” the sacrificial(?) hardwood block to gain you a little wiggle room. It’s one less point of resistance. You could easily remake this once you’re reassembling.
Sure. See attached.Why not share the design drawing with us?
A proper engineering solution.UPDATE
The blow torch did the trick. Thanks to everyone who replied, and especially to those who said we needed to get hotter.
Inside the casting we can see where the epoxy glue bonded onto the painted surface of the fibreglass, which is what was causing the problems.
OK, let the bronze cool off and then we can start looking at the pintle, which I thought we'd be doing four weeks ago
