demonboy
We have an issue with our rudder and need to remove it. There's just one problem: it won't budge. The bronze casting on the foot of the skeg was epoxy glued (Kossan epoxy) and bolted on. We've removed the bolts but the casting will not budge one millimeter.
The boat is an Oyster 435 and, as I understand it, apart from the keyway in the stock for the quadrant, there is nothing else preventing this rudder from dropping. There's a bearing in the deck underneath where it comes out for the emergency tiller but I don't see evidence of a circlip at the top or anything else that might be preventing us from dropping the rudder. If anyone knows any different, please let me know! I'd rather embarrass myself with a dumb oversight than attempt to do what I propose next...
This is roughly what the protrusion of the skeg that sits inside the casting looks like, which I believe is fibre and probably part of the original mould:
We've tried everything. We've spent literally hours with a heat gun, being careful not to damage the casting by keeping the gun below 700 degrees. It has melted the epoxy, but we're unsure if this is the epoxy glue or the fin of the skeg itself.
I've managed to gouge out a small channel at the top of the casting and tried using acetone with a syringe. Also, I injected acetone into the bolt holes where there is the smallest gap between the bronze and the skeg. That's done nothing.
We built a 10mm plate that slides into the gap between the skeg and the casting and whacked it with a hammer.
We've tried placing a lever between the top of the rudder and the hull, but all that does is move the entire assembly since the lever is offset from the skeg.
I think the problem we're having is that when the epoxy is heated, it doesn't run but turns to a rubber-like consistency, so it's acting like a rubber glue between the casting and the skeg. I've chisseled and scraped away at the bits I can see but it's not much compared to the parts I can't get to, and I don't think it matters if the casting is hot or at ambient temperature, that epoxy glue is not shifting.
The last thing we're going to attempt is to use some LPG or refrigerant to see if we can crack the epoxy, but honestly, I don't hold out much hope and I think it is time to think of something more drastic: cut the skeg between the gap.
If we did this we could save the casting (removing the crap that's going to be inside it), rout up into the skeg and rebuild it. Since this protrusion was probably part of the original mold and requires a great deal of structural integrity (it holds the rudder in place), sticking some ply and glassing over it may not be enough, so one thought I had was to place a sheet of bronze up into the skeg, glass it in but also bolt it. The protrusion would also be glassed to the correct thickness, following the shape of the casting. It might look something like this:
1. Any further bright ideas on removing the casting before cutting it?
2. Any thoughts on this proposed solution?
We are in Indonesia with limited resources, so brand names of magic solutions won't help, but base chemicals we can get hold of.
TIA
TIA
