Short shaft Evinrude 4hp info please.
mickshep
9 Jan 2003
Hartlepool
I've just bought a 2nd hand Evinrude 4hp. The plate on the leg states;
Model No' BE4BRENM
Ser. No' B08900297
Belgium.
Can anyone help with info on this engine please. eg, Fuel mix, spark plug type, possibly a workshop manual for sale, or location on the net?
Cheers, Mike.
jointventureII
30 Jan 2002
Genoa Italy
Used to have an evinrude 3hp short shaft that required a 100:1 mix ratio but the mechanic recommended using 50:1 as it wasnt used all that often, to protect the cylinders.
BobGiles
14 Mar 2005
Kent
www.designright.co.uk
hi mike.
yep i have an evenrude 2 stroke 4hp s/shaft.
the mix definately 50:1
as for the spark pug i am sure any good make will do the job.
i have a manual for the engine, though it is with the boat at the moment and not in front of me.
give me a e-mail with what you need to know and i will try and help you as best i can.
bob /forums/images/graemlins/grin.gif
VicS
13 Jul 2002
If you can't get the info here or for the link suggested by "bobupanddown" try the Evinrude section on the iboats forum at http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi
I have absolutely no doubts that you will learn what you need to know there. It is important to interpret the model number correctly as the year of manufacture may determine the correct fuel mixture.
I think the E and the N are the year identification which is interpreted from the word I N T R O D U C E S where I = 1, N = 2 etc upto E = 9 and S = 0. That would make yours a '92 model. That sound right?
I dont know what the B is at the beginning, the E = Evinrude, the 4 = 4hp, other letters refer to other things including shaft length and starting method.
