Shore power lead in the water
VicS
13 Jul 2002
A rather large 40 meter Sunseeker have their very thick shore power lead trailing in the water (about 100ft from my boat), should I be overly concerned? Will my anodes disappear overnight?
Provided the insulation is sound and there are no connectors in the water there should be no problem.
Even if there is the RCD on the supply should trip but worry if you see electrocuted swimmers in the water.
timmygobang
22 Sep 2010
on the move
www.todayiboughtaboat.eu
Do you mean the middle of the cable is drooping in the water, or it's disconnected and the end is immersed?
Sorry should have added the middle of the cable is drooping in the water (quite a lot of it). I wondered if there would be any electrical discharge. I'm sure when something similar happened to me last year a passerby said I wouldn't have any anodes left if I left it dangling in the water.
Searush
14 Oct 2006
- up to my neck in it.
back2bikes.org.uk
Unless it has a number of pins shoved thro the insulation into the conductors there shouldn't be a problem. But if it has been lying on the pontoon for years & regularly trodden on by heavy people in big boots & trollied over with grossly overladen loads so that the insulation has been damaged then . . .
the RCD will probably trip anyway!
Anodes decay with DC current leakage, not AC. The steady one-way current flow removes material, AC does not do that.
timmygobang
22 Sep 2010
on the move
Thanks Searush that's settled my mind :)
Now I just have to sort out the dark navy warps, that have been cunningly placed across the pontoon acting as a trip wire which nearly caught me out last night :S
Leighb
8 Aug 2007
Suffolk
This happens all the time in certain marinas where the shore power connection is on dry land, not on the pontoon. If you have the cable reasonably tight at HW, it will pull out or break as the tide ebbs. If you have it at an appropriate length for LW it will inevitably end up in the drink at HW. Provided the cable insulation is sound there is no problem, just make sure that connectors if any, are not going to get wet.
TheEcho
26 Aug 2013
When we berthed in Holland a loop of our mains cable blew into the water one winter. Great Crested Grebes built a nest on it.
If you passed enough current through the cable, you could have given them some delightful under-nest heating to help them incubate their eggs!
johnalison
14 Feb 2007
Essex
I think it is more of a potential problem than a real one in most cases. I have only once seen specific instructions to keep cable out of the water and I think it was St Quay.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Didn't you tell him to pull the other one? ;-)
Mike.
Dabhand
5 Jan 2010
South Devon
Any tropical fish keeper will tell you that mains cables are submerged in the tanks to provide power to the heaters, and there are many times where you need to put your hands in the water to attend to the fish.
