Shopping around for a good deal.
rotrax
17 Dec 2010
South Oxon and Littlehampton.
Over the years I have spent thousands getting motorbike parts re-finished. To the extent where our small motorbike shop was the 'go to' place for fuel tank refinishing. Our guy, Landowski, was the dogs dangly bits with a bike fuel tank.
I like to think I know where to get a good job done and at a sensible price, and am aware of the benifits and shortcomings of different finishes.
Our boat has a Hoyt Boom for the jib. Gives excellent sail shape, acts as a kicker/vang with a free sheet and is self tacking. It is a 5 inch diameter aluminium tube, 40 degree bend in the pivot end and is 12 feet long.
Our boat was supplied when new by Peters Opal and they or their contractors failed to use any insulator between the S/S boom hardware and fixings. This caused galvanic corrosion which started to lift the silver powder coat finish. We decided to have it blasted and re powder coated. The OE finish got scruffy after nine years, so with the use of Duralac the new finish should last far longer.
We took it to a local metal refinishing specialist who said they could do it quickly and at the right price. Local to the boats mooring in Sussex, tricky thing to move around being 12 feet long. It just squeezed in the Fiat Doblo with the tailgate open a little.
I began to get twitchy when we had no return calls re price and timescale. Eventually I pinned them down, got a quote for almost 400 quid!
Yesterday First Mate and I drove to the boat, checked mooring lines, engine/genset tube heaters and the big tube heater and dehumidifier and timer. All OK.
Went to the metal refinishers, collected the boom, fetched it home on the roof of the Doblo. I had custom made holders for it using the roof bar mounts.
Took it to a local guy in the interestingly named hamlet of Gozzards Ford, adjacent to Abingdon Airfield. He comes highly reccomended.
He gave it a proper old fashioned look and said " Be 80 quid to a ton mate. Next week do yer? "
My mistake was perhaps telling the first bloke it was from a boat..........................................
I e found that there are a surprising number of small guys going powder coating doted about all over the place, I’ve a few bits done for boat and car etc for not a lot of money, the size of the bit does not seem to effect the cost as much as I expected. Suspect the labour for prep etc is about the same.
Had you tried any actual powdercoating firms? Such as these:
Powder Coating Services in the Wellington Region
Powder Coating, Sandblasting & Patio Furniture Restoration in Wellington, FL
They probably could have included it in a batch of other items being coated, provided it was a of popular colour. I used to have to bring components to be powdercoated, when I worked for a shopfitting company may years ago, and the cost wasn't terribly high when it was part of a full batch.
The boat is in Littlehampton, we live in South Oxfordshire.
We do keep a boat in Wellington, NZ. but a powder coater in Wellington, Florida would not be suitable for bits off either boat. :cool:
My mistake was not getting a quick quote. The company I left it with promised a price the next day, took over three weeks. When I got the price and questioned it the guy obviously thought he could flannel me and get away with it.
He found otherwise.............................................
Can you powder coat a regular aluminium boom? Mine is a bit tatty, and is showing bare metal in places - I was going to paint over that, but would rather have a proper job done if the cost is in the order of a couple of hundred.
I last year added a short bowsprit using thick walled Ali tube, had it powder coated and it’s perfect. The surface was cleaned with fine grit first. Been on boat for over a year, been stood on etc and coating shows no wear or marks. It’s 1200mm long and cost me £20 to have done in a choice of colours that they had
I may be asking a question out of turn, or showing complete ignorance - but why powder coating and not anodising (which you could have completed yourself)
And
I may have this wrong, and geographically irrelevant for you, but I recall Geoff when he was at Highland Galvanisers also offered a power coating service.
Jonathan
I did look at Anodising mine, but when I looked at it some of the chemicals needed were quite nasty and hard to get and from what I saw doing large items needed guide significant volumes and the end result not as good as having it professionally done. Could not find a company willing to do it.
Powder coat often seems to end up looking OK for about 5 to 15 years then suddenly peeling off to reveal a white mess of corroded ali.
At my age that will become someone elses problem.
But, at 80 to 100 quid, not too expensive to refinish.
Most Island Packet Hoyt booms never need refinishing.
Peters Opal supplied this boat as they were going bust.
Perhaps that had something to do with the poor assembly practice. Pretty certain had Duralac/Tefgel been used on assembly when new I would not be posting on here about it.
Amen to local guys in small workshops !
My 30 year old stainless steel water tanks were both leaking four years ago (well weeping seams really). I was quoted ludicrous money for replacement even for plastic ones. A local small engineering firm took the old ones, cleaned them up, rewelded the seams and pressure tested them - £140 for both.
Also had a stainless bolt shear in the prop shaft flange when removing it a few weeks ago, they drilled it out and retapped it for £20
