Shocking Splash Day....Again (longish tale of disaster and ineptness)
tinkicker0
6 Mar 2008
Under a cloud - its just started raining
And all down to my ongoing ineptitude.
Aye last year it was as a newbie with a newly minted ICC forgetting his training and heading down a blind fairway in a gusting 30 knot from astern wind.
Then expecting to turn a single sterndrive boat 90 degrees into its finger berth.
As can be expected I found myself blown into the partly filled in old boatlift structure at the end of the fairway with the prop chewing the bottom and only judicious use of the boathook as a punt and ramrod saved the day.
I found out that day that boats travelling sideways have no brakes, no matter how hard you press on the bulkhead with your foot.
Took me a week to get the courage up to take her out of the berth again. /forums/images/graemlins/ooo.gif
This year after replacing the bellows and rebuilding the driveshaft assy on the drive, boat was arranged to go in the water sometime this week and marina was going to text when it went in. Important for the nerves that since I have a particular paranoia about poorly fitted bellows sinking the boat.
At the same time as the bellows, I changed the plugs, HT leads, dist cap and rotor.
No problem as hey, I bin a automotive engineer for over 25 years.
Started her on sunday on the muffs before she went splash to much shrieking and blue smoke, plus non spinning alternator.
Freed the alternator off and she was running again and sounding like she was imitating a rap artist firing a hand cannon.
She smoothed out (a little) and bad fuel in the carb was diagnosed. "Soon burn off" said mr overconfident on my right shoulder.
Tuesday, nice evening and out of work early, decided to go to the marina to finish recaulking the rubbing strip I started sunday before she hit the water.
Arrived at marina, no boat, just the chocks, looked at the slipway pontoon and there she is bobbing about in the wet stuff.
On board, engine cover up to check bilge for water and yep must've been a foot deep or so it seemed.
No idea if this was the result of 1 hour or 48 hours in the water and paranoia cranked to maximum.
Decided to get her to the berth and investigate there.
Started her up, rough as a piano dropping down a flight of stairs, told SWMBO to cast off from the pontoon and meet me at the berth. About 3 feet out, pah the motor stopped and failed to restart, only SWMBO's cleat lassoo skills saved the day.
Plugs out (broke one) number 2 and 3 cyls not firing. Put old plugs back in. Engine started and seemed a little smoother.
Cast off again, turned around and headed for the berth at the other side of the pontoon.
Straight ahead is the marina entrance on to the river and I have to make a sharp turn to port, to pass the end of the pontoon and my berth is literally six feet away from our starting point - on the other side.
So bow pointing straight at the river exit, not more than 30 feet away, bloody motor goes Pah again and I have no brakes and very little steering.
I resolved to hit the bank rather than glide out into the river and drift downstream.
Luckily the engine restarted at once and I made it to the berth with shaking legs.
No sign of the water rising further in the bilge and no sign of water leaking in, so SWMBO and I "enjoyed" a melancholy cuppa whilst my overtaxed brain tried to think of ways to stop the bloody thing sinking.
Thought of tying her up with all the rope we had so she would only sink a little, so open the anchor locker in the forward bilge to get the big mutha ropes out and to our surprise they were sopping wet. Evidence of bilge being quite full too. Mmm how'd that happen?
Light bulb flashes on in the head. She had a slight bow down attitude on the chocks, now the weight of the engine makes her stern heavy.....Solution bail out the bilge and see if any more water comes in. Bilge duly bailed out and wiped dry and my "foot" of water measured out into plastic cup totalled about one and a half litres /forums/images/graemlins/confused.gif
The water I drained out of the block and manifolds after winterising her had to go somewhere and it was not out the transom plug hole apparently.
Moral of thar particular tale: a little water in the bilge added to huge paranoia inflates the amount of water present by a factor of a thousand. /forums/images/graemlins/laugh.gif
As for the misfire, being a ford trained techie and used to old style distributors turning counterclockwise Mmm. If number one plug lead is at 5 oclock, number 3 is at 1 oclock, number 4 is at 10 oclock and number 2 is at 7 oclock.
Wrong, this particular distributor of satan turns clockwise!
Moral of the tale: Don't substitute experience for a good read of the workshop manual before tackiling a job.
As for the alternator...thought about changing the beearings but not taking any chances now /forums/images/graemlins/frown.gif
Brand new one just arrived.
Now all I need is a nice electrical fire and boat burned down to the waterline to have collected the full set.
Where's my manual!!!!
I am paranoid and extremely protective of my boat, treat it like a baby and have these snags every year, yet others leave them in the water, fail to winterise the engine, lock the door and walk away till next year, then about now, walk aboard, start the engine and go on their merry way whistling a happy tune.
Ignorance is bliss on their part or are the fates just having a laugh at my expense?
Any one else have splash day disasters or is it just me?
/forums/images/graemlins/tongue.gif
Thanks for that. It's reassuring to know that other people also make mistakes from time to time.
The last time I had my Centaur lifted back in, I forgot to mark the throttle lever "F" and "R" (it had been written on in felt tip pen, and I'd polished it off in the yard). So headed back to the pontoon, turned in to the finger, and gave a dollop of reverse expecting to stop nicely and tie up. Unfortunately I applied a large dollop of forward instead. What a crunch! The bow must have risen 6 feet into the air as she plowed up and over the pontoon. Fortunately there was minimal damage, and my neighbour on the other side of the finger saw the funny side, once he got over the shock.
Everyone makes mistakes Mr Indestructable, its just that those with inflated ego's won't own up to them.
Show me a guy who never makes mistakes and I'll show you one who A. Never does anything or B. Is a liar.
In my case its just that my mistakes tend to be rather spectacular.
But hey, I'd rather tell the tale of ineptitude and try make people laugh about em than bore people with my successes.
Now it's to the marina, with the new alternater and those lovely high capacity wires. Full battery output plus 55amps should warm em up nicely.
How long does it take for a boat to burn down to the waterline and should I get all my tools and equipment off first before making any connections?
/forums/images/graemlins/grin.gif
A good, honest tale, very well told. Thanks!
At the risk of sounding like a smart Alec, it's worth remembering that boats do, in fact, have brakes...we call them anchors.
They can also useful for turning into a tight berth.
Sorry!!
About 1992 I bought a wooden fishing boat(24 feet)with twin Perkins and had it delivered to Plymouth from Topsham.managed a couple of trips in the sound before going back to work(Holland).Came back after a month and took my partner for what I hoped would be a nice day out on the boat! I was on a trot mooring and after warming the engines for 5 mins dropped the mooring and came out to stbd ,just then the port engine revs went screaming up so I hastily shut it down while trying to manouvere between lines of yachts and eventually got her out and heading for the sound.Restarted the port engine again and it sounded OK so I set of towards the tamar and of we went ,me practising handling this rather sluggish fishing boat ,up the Tamar we went until time to turn round I had put stbd eng in neutral and the boat stopped with the port still in drive!!Found then that the prop shaft had sheared on the port !OK we set of back against an incoming tide,on reaching the mouth of the sound from the Tamar the stbd eng cut out!Now I was drifting back quickly towards the large Green buoy (Vanguard?)Shouted at partner to put on lifejacket and got myself forward and threw the Anchor out which did the job (eventually)and had us about 25 yards from the big Green buoy!! Managed one message on my handheld and the battery went dead!!Fortunatly a passing yacht(under sail!!)obtained a work boat to tow us back to the marina(after pulling up about 40 metres of anchor chain).So a lot of lessons learned in one trip ,how many mistakes can you spot!!!
Re: Shocking Splash Day....Again (longish tale of disaster and ineptne
Love your story...
Having a small sportsfisher with outboard power you would think there was not much work to do, however just like you i treat the boat like a baby. Lifted out in November, large cover purchased & winterised the engine. February rubbed down and antifouled with International Inter-speed... none of the cheap stuff for my ickle boat. Engine serviced by the professionals (no, not Bodie & Doyle, MB Marine!), hull and topsides machine polished, new waterline decals applied as the old ones had a few scratches. Grease seacock etc, etc, etc. Probably £700 later she is all ready to go back in the water.
Had some friends over last weekend, they have a 2005 Bayliner 285. I just asked how his pre-season work was going and looked at me with a blank face. Anti-fouled yet? Engine servied?, anodes changed..... no, he had decided to skip all that this year and leave it in the water, but he said he might get it out this coming November... He just said he was a bit busy to bother with all this fussing about and in his opinion it does need doing every year anyway.....
Sorry, but IMO there should be some sort of test. If you can prove you are completely unable to leave your boat after a weekend away without giving it a quick wash off, then you should be allowed to own a boat. If you can walk away leaving your boat covered in salt, then the harbour master should be able to confiscate it and give it to a fellow anally retentive sole like me! /forums/images/graemlins/wink.gif
The plot thickens................
Brill day at the marina, swapped over the alternator no problem, fitted new horn, set idle mixture and idle speed up on the engine, sounds lovely now, boat polished inside and out and time to take her for a shakedown run up the river for 20 mins.
No upholstery in the boat yet apart from helm seats and the battery isolator switch is at the back, bolted to the transom battery compartment. This switch is usually protected by a transom seat
Set off upriver, new driveshaft joints, bearings and gimbal bearing have certainly quieted her down and she sounds lovely and quiet now.
Check gauges, oil press 40 psi, temp 135 degrees F, fuel full, volts 14V. Everything where it should be.
SWMBO has a bag of crusts and stuff to feed the ducks with and positions herself at the rear of the boat. She spies some ducks and picks up the bag.....
I'm at the helm, time to check gauges: oil ok, fuel ok, temp ok, volts err 15v and a slightly oscillating needle. Strange, but time to turn around, must be 14.8v and a innaccurate gauge.
Get back to marina, swmbo steps off to cleat up, I kill the engine and see the master switch key laid on the cabin floor. SWMBO's bread bag has a master switch key sized hole in the side. AAAAAAAARRRGH!
£160 brand new, run less than a half hour alternator run open circuit.
Gauge is showing a 14 volt charge, but I'll lay odds on a phase down.
I'll have have to drive a 70 mile round trip tommorrow to work in order to get my scope and do a ripple test on an alternator I never expected to do one on. /forums/images/graemlins/frown.gif
Anyone know whe sells Mando alternator regulator/rectifier packs separately?
Not too bad, but, brain not in gear, plan was to change prefuel, main fuel, oil filters and oil today, MD22, thought id change the pre filter first, run the engine to fill it then do the main one. Carefully take it all apart, you know the one, a CAV 296 stack with a glass bowl, undid the drain tap in the alloy base and thought oh I will put some volvo grease on the thread so that I dont break it if the [--word removed--] hits the fan and need to drain water in an emergency. Just then the phone goes, answer it and put the stack back together. Thinks Ill pull a bit of fuel through with the primer, pump and pump, glass bowl stays empty, get socket on front of engine, turn looking for the sweet spot on the cam for the pump, nothing, hmm, Ill try a start and see if it will pull through. It started ok, and it ticked over for a minute while i was watching the glass bowl, nada, nothing dim fuel and then the lightning bolt struck, the drain plug that I was going to grease was still sitting on the table, the phone call had distracted me!! Interesting the MD22 seems to run forever on a pump full of fuel and self bleeds, bear in mind it must have run for a minute while I attepted to pull fuel through, then once I put the plug in it pulled the fuel through the CAV stack without bleeding, I then changed the main filter and it pulled the fuel through that without any priming or bleeding, so I am impressed.
Stu
