shetland 500 sea fishing
happyjack
7 Aug 2007
rochester kent
plate says shetland 500 and max 50HP it is filled with foam ?
any info on this boat please and is it ok for sea fishing ect /forums/images/graemlins/confused.gif thanks kevin
ShipsWoofy
10 Sep 2004
Shetlands were / are pretty good and tough little boats, The answer is yes indeed.
Having just seen one on b&O, I thought you meant a different model, nice looking boat for angling.
We always used displacement boats, for spending a long time at anchor do you really want to be in a semi or planing hull? I do get the idea of getting to your fishing ground and back between any weather, I would rather have the boat that suited the purpose for me.
Good luck with whatever you decide.
Where are you by the way..
Clyde_Wanderer
15 Jun 2006
Glasgow
Try the Shetland owners assocciation, they are brilliant, I was a member before I started sailing, as I had a Shetland Black Hawk.
I wouldent recommend going to sea in anything more than a force 2-3 in any of the smaller Shetlands, or similar sized plane hull boats, I have had a few unkindly experiences in the inner firth of Clyde.
Good luck.
paulm299
25 May 2007
Port Talbot
I have used one and my Brother uses one regularly for fishing . I currently have an Oldenburg 17 Day Cab ( anybody know of any owners clubs ? ) in use in the Bristol Channel . Slightly more sporty but I am confident in it up to F4-5 . Maybe because it has more freeboard or we do not get the full force of the Atlantic like Clyde_Wanderer .
Lakesailor
15 Feb 2005
Near Here
I have a planing hull which is not unlike a Shetland in that it has tunnels and sponsons outboard. It is very stable indeed at anchor, and I keep it on a swinging mooring where it is very stable. More stable than my B-in-Law's Langstone Fisherman of the same LOA
Kawasaki
21 Jun 2004
Anglesey Wales
He is either on the Forum or in the Rochester area according to His Bio Doggy!
I presume You mean the Alaska 500 ?
Cracking fishing boat if so.
duncan
Home mid Kent - Boat @ Poole
great little boats - nice balance of cuddy and cockpit overall but many find the cockpit a little on the small size for fishing. 2 guys no problem though.
most are remarkably 'solid' having been built in the era of thicker grp is stronger!
