John100156
I want to do an oil change on both my TAMD63P (370Hp - circa 600 Hrs) engines early September, before a trip over to Mallorca.
I know VP recommend VDS-2 for these engines which is I believe around ACEA-03 specification (not that I really know what that is save only I assume the higher the number the better the oil, but suspect that might not be strictly true either, anyway), I was thinking of using Shell Rimular X 15W40 which I believe some have used with good results which is ACEA-07 Specification.
I suppose my question is, is it worth changing, clearly I would like a very good quality oil with say a two year change interval if possible, but do not want to change unless it is felt that this might afford better protection. I do not see it could cause any problems but if any feel it might I would be interested in their comments too!
Any guidance welcome in this regard.
