vic008
Have shaft on bench trying to find the prop taper. Scribed a line for the shaft then for the taper. I come along 100mm from the intersection and measure and get 5mm. Why dont I get 10mm for the 10:1 taper?
I have not measured the diameter or radius. If you go 100mm along then up 10mm youhave a 1:10 taper.right. For 1:12 taper you would go up 10mm over 120mm. Not hard to do on piece of paper. Using a bit of 1" alu angle am able to get a good represention of the angle for the taper .
Rather than measuring angles just do as I suggest and measure diameters with a micrometer. Then you will know exactly what diameter your shaft is and the taper.
I thought all forumites had bought a digital vernier from lidl or Aldi by now!
A digital vernier caliper will be precise enough, and easier to use on a taper, wont it? Certainly more precise than pencil paper and bits of Al angle. An analog vernier would be better or even a pair of ordinary calipers.
