Greg2
Next Question![]()
Red diesel going, going, going, gone! How’s the fuel consumption versus maintenance costs equation looking now?
Next Question![]()
If you do more than 500 miles a year at planing speeds you would probably be better off with outdrives
However, add in peace of mind, then only your own experiences will help you decide.
Or ask a marine engineer what would they pick and go from there.
There is a best answer for each boat owner, hopefully people will knowledgeably choose what's best for them. I have learned loads from this forum and now know what is best for my purposes. If I did 1000 miles a year I would even consider IPS.
It's like buying a saloon car or a big 4x4 - what do you want to do
Red diesel going, going, going, gone! How’s the fuel consumption versus maintenance costs equation looking now?![]()
I’ve always had shaft drive boats as they were all either aft cabin or flybridge.If you do more than 500 miles a year at planing speeds you would probably be better off with outdrives
Has he diagnosed the failure ?On the subject I have nothing to report. Its down to the owner who is pondering over the next steps.
Not as far as I know. I hope for an update next weekend.Has he diagnosed the failure ?
At least the part will be fairly cheap and it won’t need a lift out etc. Fingers crossed for a good resultDrive plates shattered.
Delicate things these shaft drive transmissions.?
If the drive just went whilst cruising, I would fix the problem and then test it out. If there is vibration after - then yes the boat has hit something. However a drive plate on an engine that size is often just a flat but thin piece of steel with a big hole in the centre, filled with a rubbery stuff. Its rubber they don't last forever.
