Shaft dia/hp
burgundyben
28 Nov 2002
Niton Radio
If I want to run 250 Ford sabres with 1:1 boxes what is the min diameter shaft I can get away with? Assume I use monel or the other stuff, T met is it?
My shafts currently are 316 and I'd have to change them.
<hr width=100% size=1>My house is for sale, 2 beds, Hamble.
Col
14 Oct 2001
Berks
So you are thinking about it !!/forums/images/icons/wink.gif
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
robind
23 Jul 2003
sussex
Hi! as a guide mine are one and three quarter inch stainless on 235hp volvos with 2 to 1 gearboxes so more torque (via gearboxes) but less power( from engines). on a Princess 41.
Regards
Rob
burgundyben
28 Nov 2002
Niton Radio
maybe
reckon might pull 40 knots!!! Flat water only of course!!
cant find much on web ref monel shafts or t met
burgundyben
28 Nov 2002
Niton Radio
Thanks Phil, in aquamet it looks like 1.3 inches so probably 1 3/8 would do it, whicih is pants cos it means boring out the p brackets if I decide to go ahead.
Hmm, food for thought.
PaulF
20 Feb 2004
Chandlers Ford, Hants
Ben, 180hp is max on 11/4 with 316, more with monel. You will be using 1:1 boxes so you may get away with 11/4 in Monel. Give Mike Bellamy a call on 01273-410025 to be certain.
Doffy
9 Apr 2002
Suffolk
on 316 1.5" is max 263hp at 2500rpm safety factor of 2
on Monel K500 1" is max 261hp at 2500rpm SF2
on Aquamet 17 1" is max 273hp at 2500rpm SF2
From Boatdiesel.com if your a member
<hr width=100% size=1>I greet you all R Well
Nauti Fox
28 Oct 2003
Kent
www.facebook.com
Ours are 1.5 inches with 270@2800 on 1:1, and 32 years old.So I guess thats safe.
<hr width=100% size=1>No dear,the water goes in the other one.
