Shaft and Coupling nightmare
Sandrine
12 Dec 2002
London
Good afternoon all.
I was wondering if any of you had a magic receipe: I have tried to remove the shaft this weekend, the prop went OK, but inside the boat, the coupling seems to have a firm grip on the shaft.
I can see there is a key, and I removed 4 grab screws (2 on top on each other)
I cannot see anything else (pin???), and its not moving
It is bathing in WD40, poured some boiling water on it
I have tried a puller, but did not move
I have tried bolting it back to the gearbox with a nut in between, but that did not pull the shaft out from the coupling either
I have been suggested to use a blow torch but I am not great at that because of the proximity of the diesel tank (and probably the fact that there is old oil a bit everywhere)
any suggestions ?
Cheers
BTW, boat is HUSTLER 35 (1971)
Engine is Perkins Perama
BobOwen
5 May 2004
Kos
I'd try the puller again. Once its really tightened, whack the coupling with a hammer, turn puller half a turn, whack and repeat.
Heat can really help too - can you cut up an old can or something to use as a heat shield? Used in conjunction with the above 'surgical' technique, it should come off.
Sandrine
12 Dec 2002
London
I am afraid I have no space indeed to withdraw the shaft fwd
Sound like I'll play with hammer and puller, just read elsewhere that sometimes, the only way it to cut the shaft ...
scary, I'll try the rest first :)
Cheers
supermalc
14 Dec 2003
Lincolnshire.
When I took my coupling off, one of the grub screws was over the key. I'm sure you've looked but is there a thirds grub screw on your coupling.....under some paint for instance.
Years ago I worked as an agricultural engineer, and remember a similar experience where a similar coupling had been loose, resulting in a step in the keyway. Strugging in a field for hours on a cold day is one even my bad memory retains /forums/images/graemlins/smile.gif Probably one of the reasons I left the job a few months later.
sequena1
22 Jan 2005
Hi. Had a similar problem dismantling my shaft and coupling a couple of years ago as part of a major refit.The two hadn't been parted for a decade or so. Spent hours as you have working up in profanity levels and brutality. The only thing that worked eventually was to drill two holes in a half inch steel bar corresponding to two holes in the half coupling and to bolt them together with a nut in between--- as you did. tighten the bolts hard then use a lump hammer to thwack the steel bar END-ON over the nut. Retighten and wallop again. It took two hours and the only thing holding them together was
dirt and corrosion. Good Luck
JAYEL
23 Oct 2004
Essex England
Bet there is a nut on the end of the shaft burried down in the boss of the coupling, there was on my trapper. I had to lever up the engine on to blocks and pull the shaft out forward.
Birdseye
9 Mar 2003
s e wales
one old engineers trick when you get something corroded inside a fitting (eg the pin in a shackle) is to take 2 hammers and hit opposite sides of the fitting simultaneously. Using this technique I have never yet failed to undo the shackle pin on my moorings.
Failing that I would clean out the bilge and insulate the diesel tank and then use a hot air gun on the coupling.
Or split the coupling, slide it forward and then hammer out the shaft from the gearbox end.
But try loosening up the coupling wwith the hammers first - it works wonders
billcowan
20 Mar 2005
Drumadoon
When you are certain that there is NO reason it wont come off other than just stuck.
heat it up with a propane torch (mask off any nearby flammable things like rubber pipes and GRP hull etc. with bent bits of metal sheet.
when realy hot - whack it with a BIG hammer (can use lump of oak inbetween to avoid damage.)
a big Arc welder used to run a big weld down the side of the boss is another way to make it lose the will to grip. (flange has to be steel not cast iron though)
Sandrine
12 Dec 2002
London
Thanks all for the answers and advices.
The nightmare is over. After 2 week-ends of banging and bashing the couplig, I eventually decided to cut the shaft and replace both coupling and shaft.
I am now 350 pounds poorer, but 've got brand new coupling, easily taken away from the shaft this time...
P.S.: Spyro, never received your PM...
