Separ KWA 50 Cleaning
Pretty easy to do but make sure you have a new set of o-rings. I did mine very recently with some paraffin. I found details on the Separ website about what torque for the bolts that hold the bowl on. Separ will supply spares direct IIRC
There’s a good chance I’ll have a copy of the data sheet at home somewhere so let me know if you are struggling to find the info.
Hi Keith , I have the same problem . Would appreciate it if you could send me a copy of the data sheet if you still have it .
For some reason I cannot message you. Perhaps you haven't made enough posts yet or something. Try messaging me and we'll take it from there.
Hello all,
Any advice on cleaning the bowls in these units?
Many thanks in advance.
D.
I have just done mine
Turn off fuel supply and drain the unit. Undo top and remove filter then remove the 4 Allen screws and remove bowl. The blue spinner is hand tightened and can be removed for cleaning. Clean the bowl out. Reassemble unit using the original large O ring which seals the bowl. Replace filter and refill unit with clean fuel. Replace the large O ring with the one supplied with the filter. I always replace with Racor filters as they are cheaper but the small O ring seems undersized so you may need to reuse the old one. The only time I had a leak was when I used the Racor small ring.
Check for leaks when engine started.
