fearmhuir
I have Selden single line reefing. While it works quite well when it is needed, i.e. when reefing down, it is a big issue when shaking out a reef. After releasing the clutch I then have to go to the mast, pull out the reefing line fully, and then pull slack on the boom end reefing line before raising the sail.
At no time, even when the boat was new have I been able to open the cleat and winch up the sail.
There seems to be a lot of friction in the system - even pulling out the slack at either end of the boom takes effort and the 'car' in the boom can be heard moving along.
I will be back on board at the end of June, and sorting this out is on my to-do list.
Having read previous discussions regarding single line reefing, a couple of options come to mind:
1) The current line is 11/12 mm braid, maybe replacing this with lighter Spectra (as suggested by Vyv Cox previously) might improve things?
2) Replace the current Selden internal 'cars' with back to back blocks, again as per Vyv Cox? I had a previous Selden boom apart, and these 'cars' run in internal tracks with just a small nylon roller on a pin - engineering wise, this didn't seem an elegant solution.
So, how are others out there getting on with their Selden single line reefing systems? Same as mine, or able to shake out the reef without leaving the cockpit?
Suggestions welcome!
