Latest news; it looks like the pipes are full of salt and corossion as has been mentioned. The bad news is that I have to work so can't get down to do the job myself so the bill will be high hundreds (replace the pipes, casings etc rather than spend time cleaning the old ones up. Time is money)
[/ QUOTE ]Are you sure the front cover is cracked? - I would like to see it for my self if it was my engine. As for cleaning out the pipes - it is a 10~15min job - NOT hours and hours of work - get an old plastic lemonade bottle, cut the top off, fill with white vinegar and place the pipe in it and leave - the vinegar will remove the crud. Most of the crud can be removed very quickly manually before placing in the vinegar to remove the remains.
I cannot see where the "high hundreds" bill is coming from.
Artificial Intelligence is no match for Natural Stupidity
Cliff - I have a leaking oil seal ring on the counterweight cover of a Bukh DV20. I've got the flywheel off but am struggling to remove the counterweight cover. Is there a special technique?
I'm also with Cliff on this. Cleaning the pipes in situ should be relatively easy using furnox or Rydlime, a product I have used with much success. £30 for about a gallon, mix it 50/50 with fresh water, suck it into the engine through the raw water hose, leave for a few hours and job done.
