SeaMaster Engine Controls
Aja
6 Nov 2001
I have a SeaMaster 'Morse like' single lever type throttle/gear shift fitted to my boat.It is getting progressively stiffer with age.
On prising off the centre name plate there is a single screw which is easily removed. After that no amount of 3-in-1 or WD40 will allow me to prise off the handle to see what is inside and whether there are any user maintenance parts.
On the other side of the bulkhead there are 4 stainless m/c bolts sticking out. Is this the way in?
I feel that all it needs is a clean out and regrease.
TIA
Donald
Col
14 Oct 2001
Berks
Its more likely the cables causing stiffness. If so, you will have to replace them, as greasing them seldom works for long (if at all!!)
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
Aja
6 Nov 2001
Hadn't thought of that. I'll remove the cables and try the control without them. Should identify what is at fault.
Donald
Evadne
27 Feb 2003
Hampshire, UK
I had trouble trying to pry the lever off of my similar control (of uncertain parentage) until someone told me about the tiny hex-headed grub screw lurking on the underside of the lever holding it onto its spline. It just slides off then, and the whole unit can be rapidly dismantled.
rex_seadog
30 Jul 2001
Sutton Coldfield
Yes, very likely to be the cables. We've just replaced ours after 5 years and on close inspection found that the outers had corroded resulting in very stiff operation. So much so that we were having trouble engaging reverse. Our cables operate an outboard in a well and therefore subjected to lots of seawater splashing about so can't complain.
