Seacocks
PeteCooper
16 Jan 2005
West of Scotland
I am in the process of replacing a seacock on the waste pipe from my galley. The old one has what appears to be PTFE tape on the threads and I was woindering if this is necessary? Or indeed if I need to put anything on the threads or just bolt the whole thing up tight. I was also wondering if I should strip the new seacock, and apply grease to all it's working parts? All help gratefully received.
tillergirl
5 Nov 2002
West Mersea
What sort of seacock are we talking about - bronze dismantlable 'Blakes' type, ball or gate. I don't think ball valves dismantle, gates can be but have no place on a boat really (yes I got two) since they can jam. Blakes type should be dismantled and greased annually. The PTFE tape is there to ensure water tight threads which is not a bad idea but I guess for everyone with tape there are two without.
PeteCooper
16 Jan 2005
West of Scotland
It is a ball type valve, and having looked at in more detail I see that it would be impossible to disassemble it. It does seem to have some grease in it already. So you would suggest I use PTFE tape for the assembly, and also for where the spigot screws in to the seacock?
Talbot
23 Aug 2003
Brighton, UK
PTFE tape is good for water joints. Loctite sealant is better and is also good for fuel connections, but probably only available from a motor factors.
Sea Devil
19 Aug 2004
Boulogne sur mer & Marbella Spain
www.michaelbriant.com
For what its worth I always put PFTE tape on the assembly - cannot do any harm and probably makes a tighter joint.
As for stripping down and greasing there is always the problem that grease can go off over the years and harden up...
The sea cocks I use regularly never seem to have a problem - the ones that are there in case of a pipe failure so are never normally operate do seem to need re-newing more often... Use it or loose it,,,
Shakey
5 Apr 2004
The People\'s Republic Of South Yorkshire
I would use PTFE, it only costs 30/40p a roll from a plumbers merchants, it makes a tighter seal and because it's teflon it makes the nut easier to undo in future.
You only need a few turns of tape if that.
Remember to apply the tape on the thread in the right direction ie. clockwise for a normal thread. This stops the tape unwinding as you tighten the nut.
Hope this helps.
