Stemar
I have one on Jissel. The flap is rubber, and the exhaust pressure has left it with a permanent bend, so it's always a bit open, but I reckon a slap from a wave would close it.A motorboat I used to work on had a flap on the exhaust fitting, a bit like the kind of thing you get on top of a tractor exhaust. When burbling at idle it made a pleasant soft "clang clang" noise. I've never seen one fitted to a yacht, is there a reason it wouldn't work?
Personally, I wouldn't want a valve on the exhaust. I'd think, "I'm going to be sailing for the next 17 hours across the channel, and I've got the wind behind me, so I'll close it." Then dozy me would realise that big bugger seems to have forgotten the bit in the Colregs about giving way to vessels under sail and start the engine to dodge. "Oh *@%~@+, the engine's died. Now what?" An automatic one would be great until a bit of salt water finds its way into the connections, then I'm even less likely to realise what's gone wrong because it never did before, and the symptoms of a blocked exhaust would be very similar to a fuel supply problem.
