canveyrover
New Member
Hi every one can any one help I have a p32 running back from Bernham on crouch to my home morring on the Roach my port engine started to over heat i shut it down run back on one engine. I found that the impeller on the sea water pump had striped. I replaced the impeller cam & front plate ,but she still would not pump.Next i removed the heat exchanger cleand it out and flush ,found some bits of the old impeller inside. still will not pump water .I then removed the outdrive cleand it out replaced the o ring on the outdrive water intake still no water. Could it be the oil cooler as the water comes up the leg into the strainer through the oil cooler then into the pump.I am on a mud birth and have gone out to earley at times picking up mud into the strainer.
