Sea temperature reading 54℃
sealegsjim
18 Dec 2007
Windermere
The sea temperature reading on my B+G Zeus display is reading around 54℃ at present. I believe it takes it's info from the sounder transducer. There does not seem to be anything to go wrong - no moving parts etc and there does not seem to be anyway to reset the temp reading. Until recently it displayed the correct temp range 18-24℃. Do any forumites have any thoughts on the matter? Thank you.
Either the thermistor in the transducer molding has failed or you have a dirty connection, probably one of the two cables on the back of the display as the ones on the transducer are probably encapsulated. There is usually a way to calibrate the reading in the display but it does not sound like a slipped calibration is the problem. However, if you can find the setting in the display manual, it might be worth trying to reset it to a roughly correct setting to see what happens.
Richard
The temperature reading on my Raymarine ST 60 was always gibberish. As far as I can tell, it's only useful for detecting if you're in the gulf stream.
54 degrees is way outside the calibration range so it sounds like the sensor has failed - quite common. Raymarine offer a repair kit for their transducers - not sure what you have with B&G.
Yes. Don't go for a swim without dipping a toe in the water first.
Do you have an NMEA2000 "smart" transducer? If so, is it still under warranty?
Our transducer for our NSS is also overreading - its about 3 years old. I'm not concerned as the 20 year old Raymarine is still good. I'm not interested in a replacement unit, the current unit is well adhered in the hull and would cause immense anguish to remove.
We use ours (the Raymarine unit) as a navigation aid as the, warm, East Australian Current flows south at anything upto 4 knots and one needs to ensure you are in the EAC or out of the EAC (depending on your direction of travel).
Jonathan
I don't really have a use for the sea temperature, and the log transducer is out of the water, so I plan to experiment with a sensor somewhere on the engine.
ds18B20 :cool:
