Scaffolding sheet as winter cover
Poignard
23 Jul 2005
South London
This winter I need to do some major work on the deck of my boat and I intend to make a shelter to keep the weather off the work (and me!). Instead of using a large rectangular polytarp over the shelter framework I have been thinking of using scaffolding sheet, like this:
http://www.tarpaulins-togo.co.uk/acatalog/Scaffold_Sheeting_.html
Has anyone used it for this purpose and was it successful?
I was thinking of using three lengths. Two for the sides and one for the top of the shelter
Avocet
3 Jun 2001
Cumbria
Yes, I tried it. The rolls are about 2m wide - so, infuriatingly, most boats will be a bit too narrow to have two lengths meeting along the centreline of the boat, and running fore-aft. Also, they need a fair bit of support on the "top" bits otherwise water pools in the creases and causes sags. Joining them is easy with cable ties, and the joints are very strong PROVIDED they are made through the reinforced sections along either side or the middle. Light inside the "tent" is, of course, excellent, but on a sunny day, it can get remarkably hot (and humid) inside it. Obviously, it's dead easy to puncture it in the little squares between the reinforcing mesh, but I would have thought it would work very well for a couple of monts provided it wasn't too windy than there was a good support structure under it
electrosys
23 May 2009
Boston - gateway to the North Sea (and bugger all
Never used it - my experience is limited to polytunnel hoops - but if I were going to use it, I'd go for 4 sheets and ensure that there's an apex.
Principally in case of snow, but also to ensure that rain never pools anywhere - 'cause it's damned heavy stuff if it does.
25 Feb 2010
I've used tarpaulins made from that material. It's pretty tough and certainly lasts far better than those cheap blue tarpaulins which only seem to survive a few weeks.
The only problem is that I find the material will chaff through in time and though the hole doesn't turn into a tear it is still a bit of a nuisance. The worst point is where the tarpaulin goes over the top of my stanchions; I've tried 101 ways of preventing them from going through the tarpaulin with little real success.
dash300
12 Apr 2011
Plymouth
Bradshaws are another company that I have used that do a comercial quality clear montex tarp which will let light through also.
higler
1 Jun 2010
try contacting a haulage company for their discarded curtain side curtains. I use them and they are heavy but really do the job and are watertight.
steve_l
23 Jan 2002
Finland
Heavy duty woven polyethylene tarp. Over here about 50€ for a 10x6m tarp, can't be so different in the UK. Green one side, silver on the other. Mine is currently on it's 3rd winter. Previous one lasted 5 winters and is now rolled up as padding on top of the boat tent ridge pole (actually the mast!).
Pad the stanchions with moulded PU pipe insulation. If you don't remove the guard wires, you could run it all the way around, pulpit and pushpit included. Works for me.
One additional trick - put ropes over the tarp also andpad them with more pipe insulation where they go over any edges. This stop the tarp flapping if the wind gets under it.
Scotty_Tradewind
31 Oct 2005
Me: South Oxfordshire. Boat, Galicia NW Spain
I know that a Mr John MacMullen of Twister fame has an all over cover for doing just that with some form of frame/hoop/structure to support.
Maybe worth asking him if he is using it this winter?
otherwise that scafflod sheeting.....
http://www.tarpaulins-togo.co.uk/aca...Sheeting_.html looks the business.
I've just had a full overall cover made for my boat to enable work to continue through the winter...... cost certainly is high to do that though!
I've put the B&Q fat pipe insulation that has a slit all down one side over the safety wires and stanchions and along the high ridge that joins from 2feet above the gooseneck and back to above the transom.
If you want mast supports for the winter to fit a Twister, I know a man who has some;)
25 Feb 2010
Pad the stanchions with moulded PU pipe insulation. If you don't remove the guard wires, you could run it all the way around, pulpit and pushpit included. Works for me..
I've tried that...and used yards of duct tape to hold the insulation in place. Whilst it was certainly better it was, for me, only a limited improvement. A few days of windy weather and it still chaffs through pretty quickly.
I've found that the best solution is to do away with the tarpaulin. I now put the boat in a barn!
Linnen55
28 Mar 2013
USA
I think the use of scaffolding sheep are better option for you . Its a temporary platform, either supported from below or suspended from above, on which workers sit or stand when performing tasks at heights above the ground.No doubt its less expensive and many other benefits .
scaffold sales
