Ian_Edwards
My advice would be to get a set of electronic charts for a laptop, plus Antares Charts and Clyde Cruising pilot books and sit down with Google Maps ( or Earth ) and the charts and have a look at the obvious sheltered spots. Use Google Street map and the photos you can see online.
Then do an internet search on places that might interest you and read the pilot books. It's amazing what you can find out.
I'd then sit down with the charts and a simple navigation program and workout a route, being realistic about transit speeds and times and decide how you much time you want to spend sailing and exploring on shore. My initial rule of thumb was to plan to spend a minimum of a day exploring on shore, but this need to be adaptive, you may get stuck somewhere for a day or two with bad weather.
Tidal steams can be strong at the obvious tidal gates, elsewhere they tend to be in the 1 knot 'ish range, well worth having with you but not a disaster if you have to stem it for a while.
The tidal range is quiet variable, from 1m or less around Gigha to 4m 'ish further north
There's a lot of sheltered water to sail in and a few exposed bits which need extra care and planning, for example, rounding the Mull of Kintyre, the bit between Easdale Island Island and Fladda, or round Ardnamurchan Point.
Generally most places are quiet, but the obvious honey pots eg ,Oban and Tobemory get very busy, once you get north of Sky it much quieter.
I hope this helps, and isn't too obvious. but it the method I use when planning a trip to places I haven't been before.
