fireball
I'm in the process of converting to single line reefing. We currently have manual slab reefing and use sail ties to hold everything in place.
Having placed our order for a stackpack I want/need to make our reefing easier.
The system I intend to do is single line (for each reef) starting under the boom at the stern, up through the eye in the clew of the reef, through the back of the boom (existing block), out at the other end, heading upwards, through the tack of the reef then down to deck level and routed back to jammers near the cockpit.
We already have the hardware inplace to do most of this, so it should just be a case of adding line and re-routing a halyard to tidy up...
My question is:
Can you get blocks that allow for a smoother run through the eyes in the sail (if so - where?!) or am I better to shackle on external blocks?
Thanks!
ps: Info for those that require it: Jenneau Sun Odyssey 30 - in the Solent.
My question is:
Thanks!
