Mister E
It would be relatively easy to add a stainless rail around the top of the backs of the lockers.
Also a rail could be added to the doghouse.
We were out in a bit of wind the other day, coming out of Chichester Harbour, punching the tide, and 20-30 knots on the port bow. Jazzcat, a Catalac 8m was dancing a jig, one hull on the crest, the other in the trough, then swap.
Thanks. That gives me a bit more confidence that I could build my own. We either have to tow the flubber with OB attached or stow the OB and put the flubber on the for foredeck, where it's in the way if we want to anchor or pick up a buoy, including our mooring. Since the OB is too heavy to get back on the dinghy from on board with any degree of confidence that neither the OB or I will end up swimming, davits seem to be the way to go, but the off the shelf ones wouldn't be a straightforward fit, so a bespoke setup seems to be the way to go.Davits - GRP, made by Lightwave, who built the yacht.
Its not obvious but they can be operated by hand (each davit has a clutch), if the dinghy were light, but otherwise both use the mainsheet winch.
A GRP roof, foam and glass, would work - and be amenable to a home build. I built our helm station and the 1m transom extensions at home. You just need patience.
Jonathan
Thanks for the ideas, everyone. ol'will is right about our concerns, we're unlikely to be tipped over the side, but a fall at our age could easily end up as a mayday.
Since we don't much like our canvas dog house top, I could well see myself doing something in GRP, and that could easily incorporate a pair of vertical poles that would provide something to hang on to. Would 30mm diameter be strong enough for that?
Jonathan, I really like those davits. Are they metal or GRP?
Well you make a good point, Just the right width so you could get your bum on the coamings and tiller in hand with the mainsheet close. Feet secure on the opposite cockpit seats. very secure in all conditions.
In my new boat while im having great fun and feeling extremely at ease, the cockpit just does not work in the same way unless your 7ft tall or have an extra arm. sat up on the coamings, where You want to be, you just cant get anywhere to get a foothold on too. you end up holding on to a Stanstion. Very easy in heavy seas to end up being thrown across the cockpit. Quite amusing when you end up on top of other crew!! Not ideal but hey what is. thinking of making a triangular block for the feet to rest on from both Port and starboard sides.
Steveeasy
But a fixed table with space to hold your winch handles / beer / books etc much betterAn old solution in wide cockpits - kicking strap similar to a dinghy along the centreline .... you can stick your feet against ....
But a fixed table with space to hold your winch handles / beer / books etc much better![]()
You can probably do yourself quite a lot of harm without actually falling OUT though.Never heard of anyone falling out of a catalac cockpit, but there is always a first time. What about some extra handholds ?
You can get plates with tapped holes that you can screw eye bolts into, then they're removeable in port or during good weather.Another vote for a central tether u-bolt (or similar - something you can’t trip over or stub toes on)
Even if you have crew, they can be ..."learn to use the autohelm quickly and reliably. Makes it much easier to move around."
I am a total devotee to autohelm .....
That's pretty much my situation. Madame loves the boat, but isn't very interested in the mechanics of sailing. She's also disabled. which has robbed her of strength causes her to get tired easily. She'd rather we had a motor boat, so a Catalac with twin diesels is a good compromise; we motor or motorsail most of the time, the sails only go up if it's easy.Even if you have crew, they can be ...
... so cruising is much more relaxing if you are rigged for and completely comfortable with singlehanding.
- sick
- sleeping
- using the head
- not interested sailors
