samwise
The double skin construction of our Sadler 29 has a great many advantanges. But when it comes to accessing the eletrical wiring or adding components, it is an absolute b*****
I am about to add a Navtex and have to get a link wire from the GPS mounted over the hatch garage down to the chart table as well as drawing through the aerial cable from the stern rail. The latter will not be much of a problem, the former is proving to be difficult. There is an existing wiring run from the instrument bank and the GPS through a hole behind the instrument facia, down the side of the hatch garage, under the coach roof skin and down inside to the point where the hull and coachroof meet.
I have tried various ways of threading stiff wires, stiff plastic etc along the existing wiring route, but without success because unlike putting a mousing line down a mast, there is no control over the direction the wire or leader goes.
As far as I can see, the only way to get it done is to cut a small inspection hatch in the cabin wall ( I think it can be done reasonably unobtrusively) so that wiring can be drawn through.
Any ideas or suggestions gratefully received.
