Sacrificial Anode Bolts
Mike Noc
19 Jan 2012
Any reason why I can't use stainless steel bolts to hold the new sacrificial anode in place?
One of the original bolts seems to have been sacrificing itself faster than the anode.
No reason from the galvanic perspective, but not necessary. Normally mild steel bolts are used, but if you are using them in wood you need to seal the bolt from the wood. Stainless runs the risk of crevice corrosion which the anode will not prevent.
Anode bolts are a different design from conventional bolts. Best to use the correct ones from MG Duff.
The anode bolts should be the best protected bit of the boat! If they are rusting away, that anode isn't doing what it's there for and you need to review. Make sure the mating faces between the anode and the bolt/nut is very clean.
In fact studs, not bolts.
usually zinc plated although MGDuff do offer stainless steel ones
fitting instructions on MGDuff's website http://www.mgduff.co.uk/leisure-craft/fitting-instructions/
