S/S Tee for rails
fiddle
10 Mar 2003
North Wales (Boat)
. I have an existing pushpit, into which I need to fit an additional vertical member.
If I was building the pushpit from new I would cut the horizontal top piece and fit a standard 3 way Tee piece. However, I dont want to do that.
I am looking for a 3 way tee piece which is in two halves, and that can be retro fitted with perhaps grub screws or similar. Can you help?
Rohorn
3 Oct 2003
Paros, Greece
Hi...you might consider taking a standard Tee piece and cutting it neatly on the centre-line with a hack-saw (this will be a labour of love, but maybe it's worth it), then fixing it with three S.S. hose-clips or, alternatively, long through bolts...say, M4, with dome nuts. A commercial split-Tee won't look any neater...
Cheers.....R
bluff
12 Dec 2004
hi could you go to an engineering company ask for say 3/4" stainless dairy pipe clips which come in 2 halves bolted together and ask for a pipe to be welded between to suit your centres
