john_morris_uk
You get an assistant standing by you with the watch (showing time including minutes and seconds) and you say ‘now’ as you shoot the sight. They write the time down while you lower the sextant without altering anything and read off the observed altitude. Easy peasy.Just how accurate does the watch have to be to get a reasonable fix? Presumably there will be a second or two error in taking the sight to logging the time anyway- Or will there? Is that part of the skill? How inaccurate is a typical sub £100 casio watch over a month? Does one need to buy one of these ridiculously over priced all dancing things that measures how far one has walked to the heads in the night? I have never actually tested one as I prefer an analogue dial.
Just pressing the buttons can put one 10 seconds out & doing it whilst holding a sextant would be awkward. Transferring it , somehow, from a stopwatch is, I am told , the alternative, but a faff . I assume it would involve going below to transfer the time adjustment after every sight- Or does it? I do not know, having never tried it.
You can do it by yourself but you end up counting elephants as you lower the sextant to look at the watch. The sun moves 15 degrees every hour. That’s 27 miles around the equator every second by my calculations. Getting the time as accurate as possible produces the most accurate of position lines…
