Rusty stainless under plastic covering
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
This is my boarding ladder looking very manky. So do I just cut the covering off, clean up as best I can? The covering is to protect the sugar scoop when the ladder is down. What would be best to protect the scoop - something on the ladder or on the scoop?
Why not cut off the plastic and do a 'whipping' where it can touch - I've done this on my spinnaker pole where it touched a stanchion. I like the West Country whipping.
A thick rubber strip bonded to the hull at the contact points of the ladder on the sugar scoop would be better. Recovering the stainless is to invite continued crevice corrosion.
RIBBED RUBBER MATTING ANTI SLIP MAT 1M & 1.2M WIDE 3MM THICK VAR.SIZES NON SLIP | eBay
How does one glue it to the boat & fold it over the corner?
It's flexible. I'd guess Sikaflex 291 would do for bonding. Other rubber mats/strips are available.
But that is not an instant grab- or is it?- so if one bent the sheet round the angle it would spring off before it set
There are many different rubber strips/mats available of varying flexibility, so it would be down to the buyer's judgement. I don't think you need an instant grab adhesive when adhesive tape can be used to temporarily hold curing sections of rubber in place. I would think that an instant grab adhesive would be the wrong stuff when you're trying to work something over a compound curve.
A bright instance of why stainless steel should not be deprived of oxygen.
It's lucky that the hoses were clear and the damage could be noticed.
