mikemcgregor
Just noticed some rust developing on engine mounts during final clean up before lift back into water.
What paint should I use?
Cheers
Cheers
Hammerite!
Ok Hammerite it is then!
I used it last year on rusty engine mounts. This year the ruts's back again and I used loads too.
Probably only way to eliminate is remove, blast back to bare metal then repaint but that's a PITA with engines still attached![]()
Hammerite!
I use black Waxoyl. Never goes totally hard but dries sufficiently to not be a problem, and this does stop rust.
This is supposed to be good.
http://www.amazon.co.uk/ACF-50-Motorcycle-Automotive-Metal-Anti-Corrosion/dp/B000P1C8UO
