Thanks richard, thats good, I rather liked the swivel![]()
...Crosby's equivalent from Jimmy Green, seems to be five times the price. Happy as I am to make logical economies, the fairly tired old chain I have acquired may be more sensibly replaced, than repaired at significant cost. :encouragement:
If you used 6mm chain you could keep it in a bucket and would not need the rope at all. It would be much easier to keep clean (as you could take the bucket ashore) and dry. It could then be stored centrally and you would not need to worry about weight in the bow. 6mm chain is, obviously, smaller than 8mm and is not unpleasant to retrieve by hand, its both lighter (again - obviously) but also more 'tactile'. You don't mention the weight of your 18' but I believe 6mm is available galvanised from Grades 30 to 70.
If you have problems finding shackles to fit - send me a PM and I'll suggest a 'personal' solution.
We are using a 'one off' galvanised G80, 6mm, 75m (with a Maxwell windlass) on a 38' x 7t cruising cat (and I have spare connectors). The chain and connectors have all been tested and are the same strength, or greater, than 8mm G30.
Jonathan
A dumb non diy'ers question, If I am going to cut the rusted shackle off with an angle grinder, I presume I really want the shackle or whatever i'm cutting held in a vice? It's not like taking a haksaw to it?![]()
