Spinner35
Hello folks,
I fish Loch Ness and have recently moved location.
I’ve also changed over from a small 13” boat which i used to pull up and leave on the shore to a slightly larger boat (Orkney 16) which is on a running mooring (I think there are lots of different names for this but it’s basically an endless rope tied fore and aft).
I’m getting on ok so far, weights are on the bottom set at around 7ft deep and shoreline ropes are all set etc. I’m not quite sure where the snatch pulley should be though.
Should it be clear of the bottom held up by the buoy or should it be on the bottom of the loch? If it is suspended, how deep should it be? Probably a daft question but there are no other running moorings nearby so I can’t ask any locals.
It’s a stoney bottom and is fairly well protected from the wind although it can get rough occasionally. I’ve gone for 19mm rope and added anti-chafe material where the rope goes through the the pulley.
I’m completely new to this so any other advice would be much appreciated!
Thanks in advance!
Thanks in advance!
