TQA
- Joined
- 20 Feb 2005
- Messages
- 6,815
- Location
- Carribbean currently Grenada
I have a 44 foot cutter with a 56 foot single spreader mast [ measured from the water ]. It has running backstays which come from the same point on the mast as the head of the staysail and a fixed non adjustable backstay from the top of the mast.
The staysail is not self tacking and has its own winches.
It is a cruisers mast not a bendy tapered racers mast.
The wire backstays have a block and tackle with a jam cleat at the base and attach to the toe rail with a snapshackle.
Most of the time I sail her without the staysail unless conditions are light when I have flown the staysail. I did not bother with the backstays then.
Most of the stuff I can find on using them seems race and sail shape orientated.
Do I need to use them at all?
I am guessing that I should use them in strong wind conditions when I have the genoa rolled away and am sailing with a reefed main and staysail only, is that correct?
But if I don't use them am I going to break the mast. Would I see the mast bending well before it reached failure point or is it going to be a sudden thing with the mast getting out of column and failing?
How far back on the toe rail should I go. Is further back better? Should they be about the same angle as the main backstay.
Say I am hard on the wind, would I have both tensioned or just the upwind one? The stuff I can find seems to say tension the upwind one only but warns of mast failure if you do not switch over when tacking.
So if I need to switch over when tacking what would be the sequence of operations when I tack. Assume I am single handed. I have an autopilot with a tack option.
