sailoppopotamus
My no-name inverter recently broke down (smell of burning plastic on the boat
) and I'm looking to replace it. I've been toying with the idea of buying a rather oversized one (Victron Phoenix 1200VA, which will do 1000W continuous at 25 degrees) so that my girlfriend can briefly run a blow dryer on low for 5-10 minutes. Electrically I think this will be challenging, but fine, assuming a 120A draw. I have two 12V 150Ah deep-cycle AGM batteries in parallel and a dumb 80A alternator, so assuming I only get 50A out of the alternator I'm left with a 70A draw across the house bank, which hopefully won't harm it too much if sustained for less than 10 minutes. Obviously I'd have to run the engine for as long as the blow drying lasts.
One of the problems is that the current inverter, fitted very conveniently under the chart table, is physically much smaller than the proposed Victron. Not only would the new inverter annoy me in that location, it would also mean a total DC cable run of 8m (min 35mm^2) to the batteries. I've therefore been toying with the idea of installing the inverter in the stern cabin, and running a 220V cable to a socket close to the chart table. Regardless of whether the cable is 12V or 230V , the cable has to run through the engine "room" and bilges to get there. This would keep the DC cable run from the inverter to the batteries, which would also have to go through the engine room, to around 4m. Is this a foolish idea? Would it be safer to just run the DC cables to the alternator? Is the whole project of running a hair dryer off the inverter a dumb idea to begin with?
For what it's worth we typically only turn on the inverter on every once in a while to charge laptops, spare VHF radios etc.
