sjclewes
hi every body what is the best wood to use on my re gelcoted southerly 105 rubbing strake
how about the green production of grp
thanks every body for the great replys i think im going to have to go for teak as it seems almost imposible to find 75mm wide false teak d section
I have a teak rubbing strake on my own boat and I'm never very happy with it. Teak is a rather soft wood and it is very easy to wear it away with chafing ropes or over-enthusiastic cleaning. On the other hand if it isn't kept regularly cleaned it attracts green deposits and looks scruffy.
Whilst I have in the past fitted teak decking to GRP boats I am starting to think about the environmental impact of this use of the timber. The best teak for marine use is old-growth Burmese teak as, although teak can be grown in many tropical locations, this is the only type that has the high oil content required. I'm no longer convinced that felling this finite resource to cut up and apply to GRP boats is a responsible use but I recognise that others may hold a different view.
You can get synthetic rubbing strake made of recycled plastic which has the colour of teak and can be grained to give an attractive appearance - especially on a GRP boat. This has the advantage over teak in that it requires no maintenance other than a rub with 40grit if it gets scuffed. Secondly it can be recycled at the end of its life which is not likely to be case with a narrow teak profile. Finally it is considerably less expensive.
